Canon IRC5045 advance noises
  • romang
    • Aug 2011
    • 72
    Hi all, im not a canon tech so not sure how to test motors in service mode. I have this machine making humming vibrating sound mostly with 1-3 copies/prints. It seems to go away with multiple runs. I cant tell where its coming from and would like to run some motors, just not sure how to . Thanks
  • copier tech
    • 8172
    Re: Canon IRC5045 advance noises
    The fuser on this model can make some strange sounds, replacing the fixing film unit, pressure roller & bearings usually quieten them down.
    • serviceman
      • Jun 2009
      • 71
      I agree with Copier Tech, fuser belt is the usual noise suspect for me, especially the humming/vibrating noise.
      Motors are tested in Copier>Function>Partchk inside service mode, but there are several they say not to run, M1, M14 and M22.
      Sent from my SM-N920P using Tapatalk
      • romang
        • Aug 2011
        • 72
        Thanks for the replies I will check the fuser and try motor test next time out.
        • ss12
          • Jul 2008
          • 289
          There's also a modified fuser drive assembly if the film doesn't fix it
          • romang
            • Aug 2011
            • 72
            Thanks looks like its fuser
