Hi,
I have a IR-5050 connected as a network printer and it displays the check network connection message. The cables are all OK, tried other network cables. Carnot ping from or to the machine.
I cannot ping the machine, did a RAM clear and reset all network settings. The USB port has the same problem, cannot connect with the machine only sees the fax board installed.
Looks like an expensive main board replacement
Jose Antonio
Jose Antonio
