Ir 3300 system software & sst tools
mastrobill
Re: Ir 3300 system software & sst tools
please I need a ir 3300 system software & sst tools
please send me to email
roberto.mign@libero.it or roberto.mign@gmail.com
thanksComment
mastrobill
Hi I am a pc technician from Italy,
i need a system software & sst tools for canon ir3300
thanksComment
thanks
mastrobill
What is the problem? I have ir3300 locked and I urgently need the program. If you want send me email with the program i thank you. I would be delighted to write another post, but at the moment I need urgently the softwareComment
shlai
Please Help,
I need a Canon Sst tool ver4.22 and above,
Please helpComment
Re: Ir 3320I/2220i system software & sst tools
Hello...!
Im stuck with my machine.Somebody please help me with the sst files please
Thanks in advance!
My mail- akhilk.priyatam@gmail.comComment
I have the current SST files, email me if interested.
Paul@justmanuals.comComment
Can you please send me the password to downoad sst
zoranpetkovic.petkovic@gmail.com
styles
Re: Irc 3880F
i have a canon irc 3880f from japan and it came with a japaneese
language on screen, i asked them to send me an english hard drive.
i got the drive but now my machine wont switch on it just warms up and the screen
stays blank, i replaced the old hard drive but still no joy.
ashComment
Re: Irc 3880F
ash
* Additional Function key > Common Settings > Language Switch, language switching is enabled./ check if ON ?
It may be set to OFF to prevent below
put back the original HDD &
TRY this first
Press: * Additional Function key
Press: Common Settings
Press: The up/down arrows until (Language Switch) appears.
Press: Language Switch
Press: On
Press: Arrow keys up/down to display desired Language/Select English
Press: Done
Note: If the improper Language still comes up turn the machine off and back on.
if not able to do above>
get into service mode to check below items>
SERVICE MODE
press Additional Functions Key (once)
press #2 & 8 key at the same time (release both)
then press Additional Functions Key again (release it)
go here-----------
COPIER>DISPLAY>VERSION
look & see if ENGLISH is loaded in Firmware ver.
if listed> go into>
COPIER>OPTION>BODY>CONFIG
This selects the multiple firmware programs held on the hard disk, and selects the unit's country, language, destination and sheet size series.
Attention:
The settings take effect after the main power switch has been set to OFF and then back to ON.Last edited by teckat; 05-14-2013, 05:24 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
