adv 6255
  • roho
    • Mar 2009
    • 844
    [Error Code] adv 6255
    I have a machine that throws the occasional e060 0002 error code. The device was able to reboot. I checked over the primary corona, and although it seemed fine, I replaced it nonetheless, and the error has returned. The customer has been able to reboot, so my feeling is the corona assembly itself isn't throwing the code, but something else machine side. Wondered if anyone else has encountered this, I didn't see any bulletins regarding this. Thanks in advance!
  • lilleputte
    • Jan 2013
    • 153
    Re: adv 6255
    Hi , I assume that you have read the service manual and followed the steps ,
    The final steps are
    2. Replace the Main Driver PCB (PCB2).
    3. Replace the DC Controller PCB (PCB1).
      Re: adv 6255
      Have you cleaned PS94 ?
      • bryand
        • Jul 2008
        • 92
        Re: adv 6255
        I would have the power checked, these advance boxes need pristine clean power. Bad power seems to cause strange problems, sometimes clearing the dc controller or reader controller will solve some.
        • roho
          • Mar 2009
          • 844
          Re: adv 6255
          I have read the manual, however those PCB's expense is somewhat prohibitive for a smaller dealership until I check out other solutions, never hurts to ask other techs. I have cleaned the sensor as well, and the small pcb contact that the corona connects to.
          Haven't done a controller clear, as I was looking to see if any other solutions are known before I go to these steps. Thanks for your suggestions, I had shimmied the contact pcb, and cleaned the contacts when on site. I'll update if the call comes back!
          • dan7777
            • Dec 2012
            • 680
            Re: adv 6255
            I would replace PS94 like was mentioned earlier. We don't replace a lot of pcb's. I don't think it is hard to get out. I have only replaced one. Take corona out and look for the sensor at the end where the shutter goes to.
            • roho
              • Mar 2009
              • 844
              Re: adv 6255
              That's what I'm thinking now as well, it's infrequent, I'd think it would be more persistant if it was a controller. I did shim that as it seemed to have some play to it. Thanks!
