E003-0002 Error
  • cscce
    • Jun 2014
    • 156
    [Error Code] E003-0002 Error
    I have a Canon IRA c5030 giving E003-002 errors. I've gone through all of the recommended steps in the service manual (clearing the error log, etc.) and also installed a known good fusing unit from another machine. The only step left is to replace the DC controller. Before I order one I wanted to see if there is anything else I should check.
    Many thanks.
  • ReproKev
    • 273
    Re: E003-0002 Error
    This may be a dumb question, but did you clear the error history or the error itself (Copier>Function>Clear>Err)? It's hard to tell by the way you phrased it.
    • cscce
      • Jun 2014
      • 156
      Re: E003-0002 Error
      I performed a Copier>Function>Clear>Err, verified that the history was cleared, turned off power at the switch, then powered up. When the boot process completed the notice to call service appeared and the error history showed a new occurrence of the E003-0002 error. Did I miss something?
      Thanks!
      • copier tech
        • 8142
        Re: E003-0002 Error
        The correct way to solve this error (If resetting in service mode doesnt clear) is to replace the fixing film ass'y WITH A NEW ONE
        • cscce
          • Jun 2014
          • 156
          Re: E003-0002 Error
          As I mentioned before, I replaced the entire fixing unit. It made no difference. BTW, the fixing unit from the problem copier works fine when installed in another copier.
          • laitang
            • Nov 2012
            • 627
            Re: E003-0002 Error
            Did u check the connection from the Fixing Unit to the DC Controller PCB?
            • cscce
              • Jun 2014
              • 156
              Re: E003-0002 Error
              Are you referring to the "drawer connector" on the fixing assembly? I saw a post referring to a different Canon series that mentioned using shims to make the drawer connector make better contact. I haven't tried that since it applied to a different series.
              • cscce
                • Jun 2014
                • 156
                Re: E003-0002 Error
                Here's a bit more info. The E003-0002 error occurs when there is no fixing unit installed at all.
                • teckat
                  • 16083
                  Re: E003-0002 Error
                  DUH '
                  someone done stoled it
                  :-} =:O
                  • niyaskarimba
                    • Sep 2014
                    • 110
                    Re: E003-0002 Error
                    we are have the same problem,but only printing or copying using Bypass.And also the image is erasing......any suggestions pls
                    • cscce
                      • Jun 2014
                      • 156
                      Re: E003-0002 Error
                      I have ordered a DC controller - the last of the recommended steps in the service manual. I'll post the results.
                      • roho
                        • Mar 2009
                        • 844
                        Re: E003-0002 Error
                        Thanks!
                        If the history was cleared then it is the wrong error clear, there's one for the history but the one you want to reset is just error clear. It shouldn't flush the history when performed, merely tells the device to recheck the fuser condition. Just a suggestion based on the wording, perhaps you've covered this step.
                        • cscce
                          • Jun 2014
                          • 156
                          Re: E003-0002 Error
                          Thanks for your input. What I did was Copier>Function>Clear>Err. I just took another look at the manual and found the Copier>Function>Clear>Err-Hist. I haven't performed that one and I get the impression that clearing the history wouldn't help. If I'm wrong about that let me know. Could clearing the DC controller have any effect?
                          To recap:
                          The fuser doesn't heat up at all. All connections look good. The fuser is known good, borrowed from a working machine, and the fuser from the problem machine is working fine in another copier. I've performed all of the steps recommended in the service manual, except the last step - replacing the DC controller. I just received the replacement DC controller. I'll install it tomorrow morning.
                          • roho
                            • Mar 2009
                            • 844
                            Re: E003-0002 Error
                            To recap:
                            That's the correct one, sorry, misread the wording. I've had a new tech fall into that trap. Sounds like the right path. Good luck!
                            • cscce
                              • Jun 2014
                              • 156
                              Re: E003-0002 Error
                              The problem is fixed! I decided to clear the original DC Controller's memory instead of replacing the board. Clearing the DC Controller memory [ Copier>Function>Clear>DC-CON ] corrected the problem.
