Canon IRAdv8105 paper jam at registration section
  • niyaskarimba
    • Sep 2014
    • 110
    [Jamming] Canon IRAdv8105 paper jam at registration section
    One of our IRAdv8105 while copying or printing the paper stops at the registration section and machine is running for more tha 5 minutes and it says print suspended.Any suggetions please
  • pr94
    • Nov 2015
    • 14
    Re: Canon IRAdv8105 paper jam at registration section
    hello, verifies if the finisher is not limited in function.
    • teckat
      • 16084
      How old is Drum_?
      • niyaskarimba
        • Sep 2014
        • 110
        Originally posted by teckat
        How old is Drum_?
        Drum is new one,we change it two months before,after that it runs only 50k prints
        • lilleputte
          • Jan 2013
          • 154
          Hi.
          What is the jam-code ?
          • niyaskarimba
            • Sep 2014
            • 110
            Originally posted by lilleputte
            Hi.
            Thre is no jam code....When we are printing or copying the print just stops at registration section,and machine runs for 4 mins and it says print suspended.......no codes is there in jam history
            • teckat
              • 16084
              remove and re-seat DRUM
              • niyaskarimba
                • Sep 2014
                • 110
                I will do during my next visit....thank you for your support.
                • niyaskarimba
                  • Sep 2014
                  • 110
                  Try to remove and reset the drum unit but still same and also checked the drum life its only 22k.
                  Any other possibilities..
                  • teckat
                    • 16084
                    Fuser Assembly Temperature Fluctuation
                    • vigour
                      • Aug 2010
                      • 1038
                      I would upgrade the firmware.
                      Occasionally there is a mismatch between finisher and machine.
                      I had one doing some weird unexplainable jam stuff soon after I upgraded firmware.
                      Luckily a new version came out soon after, which fixed my problem.
                      If you have no new firmware, try downgrading and test.
                      Normally SUSPENDED is a clue about the finisher.
                      Is it out of staples.
                      • sodinor
                        • Jan 2016
                        • 14
                        • teckat
                          • 16084
                          1-Do a Back up of DC Controller Settings > using Service Mode; Level 2 > Copier > Function > System > DSRAMBUP.
                          2-Then, Clear the DC Controller using Service Mode; Level 1 > Copier > Function > Clear > DC-CON.
                          3-Then cycled printer off/& back on.
                          4-Next, Restore the DC Controller Settings > using Service Mode; Level 2 > Copier > Function > System > DSRAMRES
                          5-Then cycled printer off/& back on.
                          CHECK YOUR OPERATIONS> for Copying > Printing
                          if that fails>>>>>>>>>>>>>>
                          Clear the DC Controller Settings and input the Front Door Settings Manually back into the Controller.
