iR3300 E602-001
  • apollo
    • Mar 2008
    • 191
    iR3300 E602-001
    iR3300 E602-001
    Could someone please help me on this code , got to visit customer on monday.
    manual says wiring fault, a mounting fault of the HDD.
    Could the HDD be faulty and where can i download the SST software.
    Many thanks
    email: apollo.copiers@hotmail.co.uk
  • prada
    • Sep 2008
    • 27
    turn on holding down 1 and 9 keys. will go through a long complete format. If blocks do not fall down through screen left to right, HDD is completely gone. Organise the coffee and a good mag.
    • apollo
      • Mar 2008
      • 191
      E602-001
      THANKS FOR THE REPLY.
      dONE TEST BY HOLDING 1, 9 KEYS , SCREEN WENT WHITE AND AFTER A WHILE CAME TO DOWNLOAD MODE.
      iF THE HARD DISK IS GONE CAN I USE STANDARD HDD AND HOW DO I INSTALL SYSTEM SOFTWARE ?
      I HAVE SST AND A CANON CD IR SYTEM SOFTWARE.
      FOLDER ON CD
      iR2200
      iR2200H
      iR2200N
      which one to use.
      THANK YOU..
      • bnmand
        • Sep 2008
        • 383
        if use over network use N
        Do you use the copier over a network connection via ethernet? If so, you need the N firmware.
        • nivssluck
          • May 2008
          • 228
          E602-001
          E602-001
          FOLDER ON CD
          iR2200
          iR2200H
          iR2200N
          which one to use.
          You can use standard HDD (5 GB and above) for your 2200-2800-3300 machine. If you have SST already in your pc or laptop just register your ir2200 firmware including the H and N. After registering you can format already your HDD. After format the HDD you have to load the System, Language and RUI.
          this is my email add: nivs_sluck@yahoo.com if you encounter problem in formatting your HDD.
          Nivs
          • AIT MAMEUR
            • Jun 2008
            • 59
            hai all, i have the same problem but i didn't have de SST and a canon CD IR system software, so can you help me. email : anadjia74@yahoo.fr
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              Originally posted by nivssluck
              E602-001
              This is only partially true, while you don't need to get your hard drive from Canon, you will need the same model that is in the copier now. I bought hard drives for my dealership, and the easiest path was to get the same hard drive models, otherwise you need to tweak the formatter .ift file. Not all drives were accepted by this tweak. I had best luck with same hard drive manufacturer's drives.
              good luck!
