sir ir3045 was 2nd casette lifting is good but load paper signal iam changing casette assem bly and casette and wiring and dcboard chnanged but not solve this problem
load paper
Tags: None
Re: load paper
I think the top and bottom pick up assembly's are the same except a guide and bracket. You can swap them out to see if it is the pu assembly (swap guide and bracket). On other machines a flag usually breaks. The paper stops like it knows it has paper but does not show paper.
