Canon IR 5000S error E000014-0000 fuser drive motor malfunction??
  • tonerjockey
    • Apr 2014
    • 567
    they were able to reboot before and it would go away. now it comes right back. and of corse after i replaced the web and sponge. Intravia book said fuser/ feeder drive motor. i see the diagram has two motors. i was initially thinking it was the one next to the green jam clearing knob on the outboard of the fuser. does anyone know if that code is caused by the motor and which one? the parts book shows the one by the green know as FH6-1944 (motor DC 24Vand the rear is FH6-1723 Motor stepping. any help would be greatly appreciated. thank you and have a nice evening, Jim
  • THUK
    • Jul 2008
    • 195
    Re: Canon IR 5000S error E000014-0000 fuser drive motor malfunction??
    I had this once and it was a trapped wire below the two connectors for the motor assy.
    • dan7777
      • Dec 2012
      • 680
      The pressure rollers used to cause random E014 codes. The bearings get worn. Now the roller comes with the bearings pressed on.
      • Canon345
        upper fuser rollers can cause the e014 too. This box is an oven, change your bearings at least before a motor.
        • tonerjockey
          • Apr 2014
          • 567
          great ideas guys. i also had a IR 5570 with a pinched wire below the motor and it was throwing a ? web or shutter code. and i thought that the fuser was easy to turn. i will check that. that is so common in old school. guess i am officially in "old school " now that this Friday makes exactly 37 years that i have been sniffing toner. i will let you guys know the outcome. thank you so much for the assistance. it is very much appreciated. Jim
          • Canon345
            For anyone else doing this, never change bearings without putting in new bushings too!
            • tonerjockey
              • Apr 2014
              • 567
              for now, it decided to start working ok.they we'll let me know.it dies turn easy.I suppose if I flip the coin and order a motor,I would bring the bearings.question, which motor is responsible for that code?
              • Canon345
                i have never seen the fuser motor fail on one of these and I have ran them to 5 million. Fixing motor. You can get part at precision roller.com
                  • 22999
                  Actual fixing motor failures were much more common on the iR-550/600, the previous series. I too, have never seen a fixing motor fail on an iR-5000/6000, but those machines were only 4 or 5 years old when I moved on to Sharp. =^..^=
                  • livancicm
                    • Sep 2008
                    • 96
                    HV pcb fix it two times
                    • Nhessy19
                      Its the bearings, its has been stucked up...
