customer says in morning when cold machine will not print and only flashes error light. no errors or jams in history. to fix this problem they have taped the upper right cover to make it tighter and they swear this works. i have not witnessed the problem even though i try to get there early in the cold. we have tried to recreate the problem so i can see it but no luck. has anyone seen this? i don't know where to start
irc 3380 error light
Tags: None
Re: irc 3380 error light
If you get a red error light there will be a message in the screen saying why!
If they find taping the door shut then I suspect that is your problem, usually the front door, common problem they don't always close correctlyLet us eat, drink, and be merry, because tomorrow we may die!
this model has door issues/ & poor hinges
check SW3 and it's right door actuator
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
