SERVICE BOOK
  • aco.bk
    • Sep 2012
    • 130
    SERVICE BOOK
    Hello techs.....
    Do you have some suggestion for service book (how should it look)?I need to create service book for iR ADV 82xx and 62xx series .
    Regards
  • MjarbarV2.0
    Adeptus Mechanicus Magos
    • Feb 2014
    • 68
    Re: SERVICE BOOK
    Well it needs to cover the basic things like who was the last to work on the machine, what the problem is/was and what was done to resolve it. The meter readings at the time and any parts fitted.
    After that it is a matter of how much detail you want to put in, like part numbers, call off codes, a check list for some sort of minimum call procedure that sort of thing. If you are creating one for specific models you could add a list of durable and consumable replaced parts as per Canon's tech manuals so the engineer looking at the machine can tell if anything is due for replacement and order it up for next visit.
    However it is worth remembering that the user will also be able to see this book as well, so if they start delving into it and asking questions you may find yourself trying to explaine things in a language and way they will understand!
    The impossible is easy - miracles take a little longer
    Let us not talk falsely now, the hour is getting late.
      • 23009
      Re: SERVICE BOOK
      Do you mean maintenance log? =^..^=
      • NeoMatrix
        Senior Tech.
        • 3513
        Re: SERVICE BOOK
        Upside of History Log:
        Maintenance history book/log is a good idea. I worked for one company that used History Log books mandatory. History Log improves machine efficiency an maintenance costs because the previous technician has listed every fault,fix and field service done on the machine. There is no reason for duplicate consumables placed into a machine if the Machine history is maintained correctly. Your customers can also see clearly where and when the machine is maintained. I've used the Maintenance history of the machine a few times to diagnose a fault of a machine, only because the previous technician listed every thing he tried to fix it. Using the previous history can allow you to try something different to the previous tech. I've p!ssed off one or two Tech' over the years because I was able to find a fault for the boss when they couldn't. I guess they never really understood it was a simple process of elimination.
        Downside of History Log:
        Every Tech and Salesman better have a clear understand of how to translate the Maintenance Log abbreviation codes to your customer. You don't want one Tech or Salesman saying one thing, and the next person saying something different --it looks really slight an underhanded in the eyes of your client(s). Don't use complicated numbers and secrete codes. This can be also interpreted as trying to hide something from the customer. Simple coded first letter acronyms you'd use every day as a Tech is suffice, your customer will come to know those same Log Book abbreviate acronyms and be in the know.
        Opposition company sales representatives can use your own machine Maintenance Log book in any mannor, in an attempt to boost/bend the potential sale toward their product in the eyes of the customer. So keep your Log book information truthful,clear,clean and concise where ever possible, that way it can't come back an bite you in the @sset later down the track.
        • aco.bk
          • Sep 2012
          • 130
          Re: SERVICE BOOK
          Log book is very good thing.With this book sometimes You can solve problem quickly.Maybe You can share your copy of log books or send it to me.
          aleksandar.stanarevic@gmail.com
          • Canon345
            Re: SERVICE BOOK
            I sent you a nice Log Sheet.
            • tee2520
              • Jun 2013
              • 37
              Re: SERVICE BOOK
              Could you please me too. Thanks
              ptsas2014@gmail.com
              • Canon345
                Re: SERVICE BOOK
                OK but you should PM emails. When you list emails like this web crawlers and spammers find them and your junk mail goes up.
