Canon 2020L
  • savi0r
    • Sep 2010
    • 363
    [Dead] Canon 2020L
    Hello guys. Can anyone give me some advice about the error in the image attached, please? Thank you.
  • ernesto
    • Oct 2011
    • 430
    Re: Canon 2020L
    I think unit fixing is not working..
    Before replacing anything enter in service mode .... copier>function>clear>error....turn off and turn on the machine
      • 16083
      Re: Canon 2020L
      Remove fix unit to inspect.
      E003-0004
      Thermistor open circuit detection.
      In the period from initial rotation to printing, Sub Thermistor 2 detected a temperature of 40 deg C or lower for more than 3 seconds.
      Remedy ; Fixing Assembly error, Fixing temperature detection error.
      1. Check failure between the DC Controller PCB (UN09/ J12) and the Fixing Assembly (UN37/ J123, UN13/ J13) (trapped cable, open circuit, connector disconnection). -> Replace the part in the case of trapped cable/open circuit
      2. Replace the Fixing Assembly
      3. Replace the DC Controller PCB (UN09) NOTE: After performing the above remedy work, go through the following to clear the error:
      COPIER > FUNCTION > CLEAR > ERR
      • savi0r
        • Sep 2010
        • 363
        Re: Canon 2020L
        Anyone can help me with a service manual, please?
          • 16083
          Re: Canon 2020L
          Enter Service Mode
          COPIER > FUNCTION > CLEAR>ERR
          Clear of error code
          -To clear error codes (E000, E001, E002, E003, E717, E719).
          1) Select the item, and then press OK key.
          2) Turn OFF/ON the main power switch.
