This is happening with just the Cyan. Its not digital lines and it cant be the drum because I tried another drum and get the same thing. How would you handle this problem? cyan.jpg Will try another ITB soon.
3380 Cyan Over projection print sample. What is the best way besides a drum?
Re: 3380 Cyan Over projection print sample. What is the best way besides a drum?
How's PG-10 look?If it ain't broke, don't fix it
A picture is worth a thousand words -
Light areas in the cross-feed direction
Check the Developer Clutch for that color >> CYAN
Swap that developer clutch with another color to see if the light area changes to the other color.
(Process of elimination)
Currently the part number for the Developer Clutch is FM2-3581-000**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Canon345
Thats a great idea! PG 10 looks nice and normal.Comment
