Canon 6085
  • Dzeak21
    • Oct 2007
    • 43
    Canon 6085
    I have a 6085 i dont have to much knowledge of this machine i am getting a E 003 code i have a book the tells me to look for a service button on the inner panel button have no clue.
  • lakeman78701
    • May 2008
    • 44
    service switch for 6085
    when you open the front door, look up on the left hand cover panel and you will see a small hole about the size of a paper clip...push something in that hole. a paper clip works...you should see a dollar sign$ on the led readout...then hit the * key and that should put you in the service menu.
    • Dzeak21
      • Oct 2007
      • 43
      Now is it on the left or right side i took off the left panel around the fuser and the panel right under the display but see no holes beside the screw holes.
      • lakeman78701
        • May 2008
        • 44
        if you took the panels off, then just look for a blue or black button, it should have a sv or sc in small type around it. it may be on the right side, that machine is so old now, I havent worked on it for a while...put there is a small hole in one of the panels as you view it from the front. the service switch is behind that hole
          • 23002
          I haven't heard any discussion about the E003.
          The most common source of these codes is a bad connection at the modular connector at the back of the fuser to the rear frame. Occasionally I've had luck with soaking the fuser oil out of both ends of the connector in contact cleaner. If you've had arcing or bent pins forget using that connector and order both ends of J50. When installing the rear frame side use screws that are 6mm longer and insert three washers to space the connector deeper into the cavity, closer to the drawer. Have an assistant close the drawer slowly while you are in the back, to see if the connector bottoms out. If so, re-shim so the connector does not bottom out. It will soon shatter if not shimmed correctly. =^..^=
          • eherrera1004
            • Sep 2008
            • 8
            about E003
            remember the fault code E003, means unit fuser in conflict, first you have to measuring the continuity of the fuser lamps, check the thermal fuse, and all those parts work good, so change the thermistor. Then introduce in a service mode, press the swicht, press in the touch panel, * 4 * move to clear error, and press ok, so make POPO, and wait if do you want use the service mode again but use * 1 * press analog and you see the tempeture of the fuser, the correct tempeture is between 190 to 210 centrigrades.
            good look
