Canon IR3030 Clicking noise
  • brewster67
    • Jul 2011
    • 167
    Making an intermittent clicking noise while making copies. Wondering if there was a way to turn on individual motors and clutches to try to isolate it. Can't find anything in the manual. Thanks
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: Canon IR3030 Clicking noise
    Clicking noise is usually around fixing unit.Use service mode and inspect motors and clutches.(Read manual again)
    COPIER>FUNCTION>PART-CHK
    Be sure to remove the Toner Container before Bottle motor is activated.
    • dan7777
      • Dec 2012
      • 680
      You may be able to isolate noise with part check in service mode. Sometimes the main drive unit will make a noise. I have replaced a couple for noise. Don't think it was a click, more like a loud errrrrrr.
