scan to email using gmail suddenly stop working ,it was working fine with below port
port used smtptx 465 and also tried with 587
now it is not working
Try Changing the DNS :-!
Hi
customer has two machine ,one machine is working fine with gmail but another machine is not working with same setting
when i scan a page immediately it is showing re sending and then error report is coming
Hi
What is the error code with it? Should be a 3 digit number if you look at the status monitor.
