unclear image
  • godyng
    • Dec 2008
    • 40
    [Misc] unclear image
    My client call a IRADV C3320 that had many white line at all color
    I will pick 4 developer , HVT & 1 drum unit for this
    Pls give me some suggestions for this case
  • DarkCrimsonFox
    • 13
    Re: unclear image
    What is the count on this machine ?
    I'm trying to remember how does this machine work. I'm trained on so much, I don't remember each machine. I rarely come across C3320.
    Assuming this machine has a ITB and transfer rollers
    If all colors are affected, I'm thinking your transfer ground may be at fault.
    I've seen a similar issue on IRA C5200; where the 2nd outer transfer roller grounding plate was faulty.
      • 23007
      Re: unclear image
      I haven't worked on Canon color, but those thin white lines sure look like dirty laser slit glass(es) to me. And the diagonal void areas sure look like poor developing, all 4 colors, as in dead or depleted developer.
      Let me know what you discover.
      • DarkCrimsonFox
        • 13
        Re: unclear image
        I heard a similar issue from a tech. A C5051 was sucked dry in each dev. He had to replaced all 4 and HVT. Not sure if the found the cause.
        Try and pin point the issue if you can.
        *** Maybe check your voltages according to the GCD
        *** Update firmware as well
        If I think of anything else, I will let you know.
        • teckat
          • 16083
          Re: unclear image
          Poster has a ADVANCE C3320, not a iRC Printer.
          Two different animals.
          Test Print Lines are paper feed direction.
          First_Clean dust proof glasses all colors.
          Void areas in all colors__ check paper stock.
          Drum ages_?
          What is your printers environment./location._?
          • Zeldaman
            • Mar 2011
            • 946
