Fuser Temperature
  • sniper2g8
    • Jan 2013
    • 117
    [Misc] Fuser Temperature
    How to increase the fuser temperature of IR ADV 5051i
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Fuser Temperature
    COPIER>OPTION>IMG-FIX. Find the manual.
    I hope you know what you're doing.
    • teckat
      • 16083
      there are too many selections for COPIER>OPTION>IMG-FIX in Level 1 and Level 2 to play with heaving no manual.
      best to explain > what is the issue u are having ? or need to rectify
      • MunsterTech
        • Sep 2014
        • 380
        hi,
        interesting....was only checking the manual today ref this....We have a tech in our motley crew that increases fixing temp on nearly every machine he goes to, its a pain as now i have to check machines default temp setting to see if he increases it. Especially on the ir30/32225/45, sort of series, he says it get rids of the paper curl with damp paper. I disagree and say it actually makes it worse...any thoughts?
          • 22999
          Originally posted by MunsterTech
          hi,
          It definitely makes it worse. Lower temp reduces curl.
          The only time that I have increased fuser temp (and with reservations), is when the enduser refuses to select the correct media type. And it's not just stupidity. The enduser discovers that certain finishing functions become unavailable when the proper media type is selected. =^..^=
          • V-P
            • Apr 2011
            • 679
            lol
            Welcome to the stupidity club
            • sniper2g8
              • Jan 2013
              • 117
              After printing on some media it clean off by rubbing your hands on it
              • zoraldinho
                • Mar 2008
                • 5007
                Select the correct media type.Envelope,Havy1,havy2........Better then service mode.Less problems in the future.
                • teckat
                  • 16083
                  04-12-2016 post-----------Fuser Temperature
                  where have you been for one year ???
                  Acceptable Paper Weights
                  Cassette
                  14 lb. Bond to 110 lb. Index
                  Bypass
                  14 lb. Bond to 140 lb. Index
                  are u using GPR-30 Toner OEM supplies
                  MFD Printing Guide iRADVC
                  http://www.uwe.ac.uk/printing/Photocopiers/iRADVC%20Printing%20Guide.pdf
                  The paper types that can be used with this machine are shown in the following table link.
                  Icons indicating the type of paper loaded in each paper drawer can be displayed on the paper selection screen if you store that information in the machine beforehand.
                  Canon imageRUNNER ADVANCE C5051/C5045/C5035/C5030 e-Manual - Available Paper Stock
                  Changing the Basis Weight of a Custom Paper Type
                  You can change the basis weight of custom paper type.
                  • If you enter the value which is different from actual weight of a paper, paper jams may occur, and the quality of the image may be adversely affected.
                    1. Press → [Preferences] → [Paper Settings] → [Paper Type Management Settings].
                    1. Select the paper type that you want to edit from the list → press [Details/Edit].
                    1. Press [Change] next to <Basis Weight>.
                    1. Press [-] or [+] to set the paper weight → press [OK].
                    1. Press [OK].
