iR1133 Error E733
  • oombees
    • Apr 2016
    • 27
    iR1133 Error E733
    Morning Guys
    I dont know if this issue was addressed but herewith the fix as experienced by our Techs in South Africa
    Whenever you get this error, before changing boards, first just replace the toner. Voila, problem solved.
    The chips on the toner triggers this error.
    All the best
    Sent from my GT-I9190 using Tapatalk
  • dan7777
    • Dec 2012
    • 680
    Re: iR1133 Error E733
    Originally posted by oombees
    Morning Guys
    All the best
    I have 4 fax 650i get this code because they use non canon toner cartridges. I suspect you are using non canon toner cartridges also. A new toner cartridge solves this problem. Luckily my company only uses canon parts and supplies. I worked at a place that started using non manufacture parts and supplies and the service calls increased tremendously!
