Canon NP6030
  • Chris3305
    • May 2008
    • 12
    Canon NP6030
    hello again,
    how do i clear the user id on a canon np6030, i have tried pressing "stop" then "id" but it didn't work. i can't even remember how to get into service mode on this old piece of poop
  • northerntech
    • Jun 2008
    • 69
    paper clip into small hole above fuser with front door jammed with a door key. OR you can push the button with a sledge hammer
      • 23010
      This key sequence is from the NP3050, but if I recall correctly I've used the same sequence on the NP6030:
      Press *, ID, Auto Zoom, *, to enter ID mode. Press 2, then 1, to see existing registered ID's. To register your own ID choose ID # registration : 1, then enter your new four digit #, then *.
      To cancel out ID Mode zero out all ID#s. =^..^=
      • Chris3305
        • May 2008
        • 12
        Thanks Blackcat, you were really close which helped me remember that the key sequence for the 6030 is
        *, ID, Stop, *
          • 23010
          Close only counts in horse shoes, hand grenades, and atom bombs. Or so we used to say as children.
          I'm glad I was able to inspire you. =^..^=
