ir4570 B5 paper size
  • repeatcopiers
    • Sep 2008
    • 591
    I have an ir4570 in the field that is showing Cassette 4 as B5 paper size in lieu of 11x17. I have flipped the switch on the cassette and even swapped cassettes and it still shows B5 on the control panel. This is an older copier so maybe I don't remember everything, is there something in the service manual that directs this?
  • dan7777
    • Dec 2012
    • 680
    Re: ir4570 B5 paper size
    Not that I can remember. Make sure there is no paper behind cassette. Sounds like the cassette switches. Maybe you can swap from one tray to another.
    • roho
      • Mar 2009
      • 844
      I believe there is a small switch on the device itself by the cassette. It toggles to display metric or imperial size. If there isn't any paper behind the cassette I'd check that.
        • 23010
        The size switches are behind the dial on the tray, and yes I've seen some fail, or the housing break so they don't make proper contact.
        • repeatcopiers
          • Sep 2008
          • 591
          Thanks you are right, there are dipswitches that the cassette is suppose to toggle, but it must be faulty on that particular cassette slot, I will replace it. I appreciate your help.
