Mr Mawanda J
  • Joseph Mawanda
    • Jun 2025
    [Error Code] Mr Mawanda J
    Please friends it has been noted that for IR 2520, even if the Fuser film gets torn to the last piece there is no error code for that,
    unless when the Fuser element can no longer give heat that is when the machine can give an error code.
    • 22999
    Re: Mr Mawanda J
    I would agree with your statements. I doubt that it would pass any paper though, without the fuser film. =^..^=
    • Joseph Mawanda
      Re: IR 2520
      Please thanks for following, papers can continue passing through the fixing unit only if the fuser film is not finished totally or just torn on both sides
      but the fuser element will be getting weak on both exposed sides, or rather burning the pressure roller.
