ir3235 failing to update firmware
  • Jerrygbs
    • Dec 2008
    • 194
    [Misc] ir3235 failing to update firmware
    plugged in thumb drive with firmware update, threw service mode, select upgrade /over right all..
    [error]file registration error,,
    just to check the thumb drive tried in another 3235, goes all the way threw update..
    has anyone seen this before? solution?
    THANK you for replies
  • dan7777
    • Dec 2012
    • 680
    Re: ir3235 failing to update firmware
    I have some issues updating software on that series. Seems like the firmware has to be to a certain number (not sure which one) before it updates with thumb drive. Use power off holding 2 and 8 turn on until you see it is in safe mode. I have one I am waiting to use the SST to update that is really low version (have not been able to get thumb drive to work on it). I have not seen any improvements updating software as I have seen in advanced series.
    • Jerrygbs
      • Dec 2008
      • 194
      worked like a charm, thank you
