E000-0000 in Canon IR 2202
  • silas
    • Aug 2025
    [Error Code] E000-0000 in Canon IR 2202
    How to remove this code?
  • copier tech
    • 8174
    Re: E000-0000 in Canon IR 2202
    1. In standby mode,press the "Settings/Registration" key.
    2. Press the"Reset" key.
    3. Press the"Back" key.
    4. Press the"Settings / Registration" key.
    5. The service modescreen is displayed.
    6. Scroll to Printerthen choose Clear
    Use the"Back" key to exit Service Mode
    This is from memory so sequence may not be 100% accurate.
    • Biv
      • Apr 2017
      • 8
      How to fix same error (i.e E000-0000) on canon iR 2004 printer? It does not have setting/Registration key on the front panel. It just has status monitor, paper setting, ID card copy, back, reset, counter check, home, energy saver, start and stop buttons. Therefore how to go to service mode on this printer to fix E000-0000 error ? Pls help.
      • rudysemira
        • Oct 2016
        • 108
        Check the voltage supply if the requirement is 220 if below 220 like 110v that error may occur.....
        • rudysemira
          • Oct 2016
          • 108
          try it the paper setting key followed by the instruction above....
          • 40yearsplus
            • May 2020
            • 113
            Sorry i'm a fairly new member I use to work on these to get into the service mode to do this on this model you want to hit the additional functions little star, key then press the 2 and 8 at the same time and then press the additional function key again and you will be in the area you want to be. Search functions or one sub heading till you see error in the screen below it. Hit error and then clear will come up, hit clear then power unit down and back up. If the machine goes back to the code after a while you need to address the part such as the fuser unit as being the problem. Although a lot of these codes show up from line surges and brown outs. Additional function Hold 28 then release additional functions.
            Look up service mode in web search also for this model there are sites.
              thanks but this thread has been dead for over 5 years.
              • copier tech
                • 8174
                You're replying to a post from June 2017.
