iR-ADV C2220 showing " ssl error (smtp tx)" #841
  • lokeshpatidar
    • Jun 2016
    • 5
    [Error Code] iR-ADV C2220 showing " ssl error (smtp tx)" #841
    Hello,
    Suddenly, iR-ADV C2220 is showing SSL error (smtp TX) on screen. It was working fine for up to 1 year. I check the logs I found #841 error code.
    Help?
  • Crow
    Re: iR-ADV C2220 showing " ssl error (smtp tx)" #841
    Were you by any chance trying to use a gmail account when getting this error? We just had a machine start throwing this error as well and it has been working fine. We also have two of the same copiers that have the exact same settings, one fails, the other does not. Just trying to nail down where this is occuring.
    • chuckintex
      This is my scenario exactly. have some machines that do work, some that don't. all worked fine yesterday afternoon. this morning, 2 of them won't. all scan to gmail account (same one). ISP is Comcast fiber (xfinity).
      • charm5496
        • 2387
        the latest firmware updates have been resolving the gmail hosted scan to email issues lately, and make sure the machines are on port 587
        • jlee
          Just to reiterate what charm5496 said, please make sure you're using port 587 and not port 465. Google is phasing out SSLv3 and RC4, so we should be using TLS moving forward.
          On our IR-ADV c5250, I had to change the port in Level 2 Service Mode.
          1. Press "Settings/Registration".
          2. Press 2 and 8 simultaneously.
          3. Press "Settings/Registration" again.
          4. Choose "Mode List".
          5. Choose "Copier".
          6. Choose "Network".
          7. Press "Level 1" to get to "Level 2".
          8. Press "SMTPTXPN".
          9. Change port from 465 to 587.
          10. Hit OK.
          11. Hit "Reset" until you fully exit.
          12. Reboot copier (not sure if necessary, but just in case).
          • lokeshpatidar
            • Jun 2016
            • 5
            we are using gmail account. now the machine is working fine since we have just changed smtp port number to 587. before the port was configured 465 it was not working.
            thanks
            • chuckintex
              thanks! will go try this straight away!
              • kcolvin
                • Jan 2008
                • 8
                5. Choose "Copier".
                10. Hit OK.
                Hi Guys can this be changed at the web browser or will it need eyes on the machine?
                Keith
                • chuckintex
                  Keith
                  must be at the machine. these configuration options not available "remotely".
                  • chuckintex
                    In my c5045 and my ir4035 and 4025 there was a step between the 5 and 6 as this was written(the option selection), I corrected for my experience.
                    5. Choose "Copier".
                    6. Choose "Option"
                    7. Choose "Network".
                    8. Press "Level 1" to get to "Level 2".
                    9. Press "SMTPTXPN".
                    10. Change port from 465 to 587.
                    11. Hit OK.
                    12. Hit "Reset" until you fully exit.
                    13. Reboot copier (always reboot when changing network settings).
                    And yes, as with the others, this totally worked for me. I have 7 of these total, all had 465 port. 2 stopped working at the same moment. this was the fix. I'm waiting to see when/if the other 5 also have this issue. 3 of those are older and 2 are same generation as these.
                    • wseyller
                      • Sep 2012
                      • 1129
                      Just had these canons this morning where I had to change to 587
                      Sent from my Nexus 6P using Tapatalk
                      • kcolvin
                        • Jan 2008
                        • 8
                        Next question as a multi vendor dealer is this effecting other manufacturers devices?
                        if so i assume the setting should be able to be replicated to those devices
                        • LOUCAPPOZZOLI
                          Jack of All Trades
                          • Jan 2008
                          • 66
                          We run into this frequently on gmail accounts since last November or so. Google has updated their email security and are phasing out SSL 3 in favor of TLS. Port 465 is used for SSL, and 587 for TLS which is why the port change was fixing the issue. Think Google did another update last week as well and there's some workarounds for that too. Someone posted it in another thread on the Canon forums here earlier.
                          We sell multiple brands as well and when Google makes a change to their gmail settings it tends to affect all of them.
                          • copier tech
                            • 8172
                            This issue seems to only affect gmail accounts Canon, i've got dozens of Ricoh machines still using gmail SSL on port 465 with no issues. (So far)
