Canon ir2525 Can't Start up!!!
  • semsros
    • 12
    Dear All
    My machine Canon ir2525 /120 voltage, it can't startup. I already try to restart the machine many time, but some time it working but I can't not clear all in service mode(* 2 8 * > clear All). When I restart the machine agian it stuck again (can't start up).
    please help me to solves this problem...
    Thanks you
  • kuby
    • Oct 2007
    • 1362
    Re: Canon ir2525 Can't Start up!!!
    Is it throwing a Error Code? You say you are doing the Clear, why?
    • teckat
      • 16092
      Originally posted by semsros
      Dear All
      Thanks you
      Start with cleaning and re-seating the Boot Rom,
      re-seat connectors J210, J8112 & J8125, cut any wire ties on the related harness.
      Try to re-seat the DIMM Assembly
      There are several scenario's that may cause this condition:
      1. If the Boot Rom is not seated properly or defective.
      2. If the DC Controller is defective.
      3. If J210 (DC Cont) / J8112 (Main Cont) is not connected.
      4. If the Main Controller is defective.
      Through testing, it was found that voltage was missing off J8125 (Main Controller) when the imageRUNNER is in the blank display, green led on and no rotation state.
      On a fully working device, J8125 (Main Controller) measures as follows:
      Pin 1 - 0v 7 - 5v
      2 - 3.2v 8 - 5v
      3 - 3.2v 9 - 5v
      4 - 0v 10 - 0v
      5 - 0v 11 - 24v
      6 - 0v
      When the iR is in Blank display, green led on and no rotation or if DC Controller or Boot Rom is defective or J210 or J8112 is not connected.
      J8125 measures as follows:
      Pin 1 - 0v 7 - 5v
      2 - 3.2v 8 - 0v
      3 - 3.3v 9 - 0v
      4 - 0v 10 - 0v
      5 - 0v 11 - 0v
      6 - 0v
      If the imageRUNNER is in the Blank Display state and listed voltage is missing on J8125, there is no way to isolate the issue to one of the listed components.
      • semsros
        • 12
        No Error code happend, I think many stuck document store in machine, so I try to clear all in the machine.
        • semsros
          • 12
          Pin 1 - 0v 7 - 5v
          2 - 3.2v 8 - 5v
          3 - 3.2v 9 - 5v
          4 - 0v 10 - 0v
          5 - 0v 11 - 24v
          6 - 0v
          Pin 1 - 0v 7 - 5v
          2 - 3.2v 8 - 0v
          3 - 3.3v 9 - 0v
          4 - 0v 10 - 0v
          5 - 0v 11 - 0v
          6 - 0v
          Thanks for your support, I try to change bootroom but still the same (Display startup Canon,but stoping) and also changed conector wire J210 too.
          • apoxi
            • Nov 2015
            • 45
            I had this problem.
            Try to disconnect (unplug) the TCP/IP cable.
            • semsros
              • 12
              Thanks you all for your support to me!
              Now the machine is working.
              After I do following support and I was eject the battery cable behind board, and then clearing all in service mode...
              it's working ... even I try to restart machine many time...
              Thanks you
              • mdm7266
                • Dec 2007
                • 99
                Originally posted by apoxi
                I had this problem.
                where is the tcp/ip cable located?
                • mdm7266
                  • Dec 2007
                  • 99
                  Dear All
                  Thanks you
                  How did you solved the problem? what did you do?
                  • margono
                    • Aug 2017
                    • 14
                    Thanks you
                    mr. can you show me, where a located the batttery cable
                    • jio9000
                      • Mar 2020
                      • 26
                      i have an image runner advance c5235a,when it powers on , i can hear the fans but no power at all on the panel ,
                      here is a link to what it is doing YouTube
                      • GIUBOSS
                        • 1374
                        IR2525
                        Try Relocating the Dimm group there are several scenarios that can cause this condition: 1. If Boot Rom is not inserted correctly or is defective. 2. If the DC controller is defective. 3. If J210 (DC Cont) / J8112 (Main Cont) is not connected. 4. If the main controller is defective. Through the tests, it was discovered that the voltage was missing from J8125 (main controller) when imageRUNNER is in the empty display, green LED on and no rotation status.
                        On a fully functional device, J8125 (main controller) measures as follows:
                        Pin 1 - 0v 7 - 5v
                        2 - 3.2v 8 - 5v
                        3 - 3.2v 9 - 5v
                        4 - 0v 10 - 0v
                        5 - 0v 11 - 24v
                        6 - 0v
                        When the iR is in the empty display, green led on and no rotation or if the DC or Boot Rom controller is defective or J210 or J8112 is not connected.
                        Pin 1 - 0v 7 - 5v
                        2 - 3.2v 8 - 0v
                        3 - 3.3v 9 - 0v
                        4 - 0v 10 - 0v
                        5 - 0v 11 - 0v
                        6 - 0v
                        If imageRUNNER is in the empty display state and the listed voltage is not present on J8125, the problem cannot be isolated with one of the listed components.
                        • GIUBOSS
                          • 1374
                          sorry I confused the post here
                          • GIUBOSS
                            • 1374
                            maybe it's the case that you started a new discussion, however check the connections of the controller, dimm, connector.
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              +1 start new thread
                              Regards Mark
