Canon Ir3570 Error Code E0733
  • olan2168
    • 3
    [Error Code] Canon Ir3570 Error Code E0733
    Good day to all, I'm having problem with this error after switching the machine and making a copy, the copy comes out blank, no confirmation tone after making copy, then error comes out promting me to turn off and on the machine, still after making copy comes out blank, checked the main controller board for loose connection seems ok, any other workaround?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5017
    Re: Canon Ir3570 Error Code E0733
    Check ribbon cable between dc and main board.Also reseat again all connectors and memory.Do you have finisher installed?
    • olan2168
      • 3
      No finisher installed, I will try your suggestion, Thanks!
      • COPIERTEC ASSOCIATES
        • Aug 2011
        • 279
        Does the machine perform a self test print on service mode?
        If not try to change the dc controller pcb.E0733 is a communication
        error problem try to reconnect all the fibre cables.
        • olan2168
          • 3
          Thanks Zoraldinho! Did what you suggest and now it works fine. For a newbie in the copier industry, its nice to find such forum like this
          • zoraldinho
            • Mar 2008
            • 5017
            No problem.
