ir2200
  • akm
    • Sep 2012
    • 155
    [Jamming] ir2200
    Dear/CopytechTeam, i face problem with canon ir 2200 that has a jam code 0111 and i sent the jam location i need your helpthanks akm
  • kuby
    • Oct 2007
    • 1386
    Re: ir2200
    What have you done, check feed rollers, check drawer setting, check paper? We need a little help here.
    • akm
      • Sep 2012
      • 155
      Re: ir2200
      i changed the feeding rollers , drawer setting ok, the customer uses fresh paper
      • roho
        • Mar 2009
        • 844
        Re: ir2200
        I used to work on these when they were fresh and new, there were a couple that were jamming with I believe that code, fairly often. There is a large tie wrap that sometimes pinches the wires. It's the larger reuse band that should be visible when you open the side door. While not a common issue, happens from time to time. The other issue is the pick up assembly has a post that can break. That leads to skewed and jammed paper from the tray, though it usually won't feed a single sheet under that scenario. If it feeds the odd sheet, try the tie wrap.
        • Helpdeskforum
          • 28
          Re: ir2200
          sensor lever ps12 in the feeder is too slow, remedy: set the spring from this lever one winding higher for more force (you can do this when you remove the feeder unit )
