Error Code Every time Copier Switch on...
  • digenius48
    • Aug 2014
    • 10
    [Error Code] Error Code Every time Copier Switch on...
    Two of my Copiers Giving this error every time i turn them on Please help me
  • Helpdeskforum
    • 28
    Re: Error Code Every time Copier Switch on...
    try clear error in service mode, otherwise replace film assy
      • 23008
      Did you attempt to swap fusers? I'm pretty sure they are not compatible. =^..^=
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        Are they on the same electricity grid?
        How many prints have Fix assy?
        Did you try to clear error?
        • digenius48
          • Aug 2014
          • 10
          No i never swap the fusers
          the error keeps coming up every time i turn the copiers on.
          • digenius48
            • Aug 2014
            • 10
            Yes that's basically what i does be doing all the time clear error
            okay ill do some research on the film assembly thnx
            • Helpdeskforum
              • 28
              you have to clear this error in servicemode after replacing the fixing film assy
              • teckat
                • 16083
                make sure to note the printer voltage when changing fix film
                can't use 230v film unit in a 120v or a 120v film unit in a 230v
                FM2-1793-010
                FIXING FILM UNIT iR4570/iR3570/iR3530/iR4530 =120V
                FM2-1812-010
                FIXING FILM UNIT iR4570/iR3570/iR3530/iR4530 = 230V
                FM2-1793-010
                FIXING FILM UNIT iR3030/3035/3045 = 120V
                FM2-1812-010
                FIXING FILM UNIT iR3030/3030N/3030A/3035/3035N/3035A/3045/3045N/3045A = 230V
                E000 = fixing overheating
                E002 = fixing assembly low temperature
                iR3570----e000-0001
                fixing film could be caked with toner.
                check latch Main Right Side Door (releases and applies pressure to the fixing film)
                iR3035-----E002-0000
