iR 2270 / 2870 cannot scan to email
  • lionex3d
    • Jun 2013
    • 41
    we are slowly having problems with this model suddenly not being able to
    scan to email.
    customer call in for scan to email issue and the technician did all
    necessary troubleshooting at the customers place:
    check:
    network settings tested ok
    dns settings tested ok (can ping google server)
    email settings checked ( server, authentication, port) all OK
    tested using gmail & company email ( email testing account ) send failed #752
    tested using a no authentication mail server ( email testing account ) send failed #752
    restores the machine to factory settings and reconfigured all the
    settings.
    still error #752 cannot connect
    we pulled other ir2270 and ir2870 from the workshop and tested it,
    both were unable to do a "scan to email" even thou it was
    able to "scan to email" previously (based on the send log).
    tested other canon models with the same settings and all results are OK.
    scan to file is working OK
    any idea on what might be causing this particular model to fail in sending email?
    thank you.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: iR 2270 / 2870 cannot scan to email
    Here we talk a lot about #752.
    you may get an idea
