IR2525 Light header
  • digicor
    • Jul 2008
    • 1159
    IR2525 Light header
    I have replaced the drum unit, cleaned all the scanner glass and this IR still has a light header only in copy not in print and ive cleaned the optic any ideas? thank you
  • digicor
    • Jul 2008
    • 1159
    Re: IR2525 Light header
    Misstake, there is a light shaded area on the paper in the print,I have checked the dv rollers, they both look clean, there is dv all the way across the dv roller, is there a laser lens some where to be cleaned?
    new drum unit installed....thanks
    • mosey1100
      • Mar 2009
      • 143
      Yes there is a laser in this copier. It is under the output tray and probably is dirty along one edge of all the mirrors in it.
      • digicor
        • Jul 2008
        • 1159
        you mean inside the laser? I cleand the outside lens, can this be removed from the top by taking the out put tray off?
        • teckat
          • 16083
          Transfer Roller may be out of position.
          Check the Pins that holds the transfer roller in place.
          SEE EXAMPLE -------->of undamaged rear side Transfer Hinge Pin
          The part numbers for the Transfer Hinge Pin are as follows:
          FC5-1536-000, Transfer Hinge Pin (Rear)
          FC0-4340-000, Transfer Hinge Pin (Front)
          • mosey1100
            • Mar 2009
            • 143
            Yes you can remove laser by taking the output tray off and it is under it. The cover comes off laser and you can clean the mirrors VERY CAREFULLY.
            • Canuck
              Tech Specialist
              • 1713
              Yes these pins come out very often. Do a skyshot or test5 and open the door while paper passes by drum. Light on drum image...laser,charge,dev,etc. Not light on drum would be transfer
              • digicor
                • Jul 2008
                • 1159
                thank you for the info, ill take a look at it
