Ir2230 Dirty output
  • tamboknon
    • Sep 2015
    • 62
    Ir2230 Dirty output
    Hi Sir, I'm working this machine IR2230 I already replaced the whole fixing assy still the output copy is dirty. Cleaned the paper path and try to jammed the machine to determine where the problem occurred still cannot determined where it is. Anybody encounter this problem. I'm glad to hear from you. Thank you so much
  • ernesto29
    Re: Ir2230 Dirty output
    If you pass your finger in the dirty area and the ink is not fixed it seems the new fixing film is wrong.....
    • Burdy500
      • May 2016
      • 44
      Latest firmware?
      kind regards
      copierfan
      • Canuck
        Tech Specialist
        • 1713
        LTR,LTRR,Legal...Orientation would be helpful(actually mandatory). All trays? Looks like starwheel on LTRR or legal but you say you replaced fuser assembly. Does toner rub off still? You can't put wrong heater/film assembly...different connector. Something dragging right after transfer. Mylar at bottom of door deformed? I've seen this cause dragging line but from bypass. Need more info...
        • JPiek
          • Oct 2014
          • 435
          Is the dirt there if you print color ? or just when black ? Need to check to rule out drums... If only on black and LTRR, check the black drum for any damage...
          [edit] my mistake, IR2230, not IRc2230, so its monochrome
          Johan
          • Burdy500
            • May 2016
            • 44
            IRC than it is the drum-unit
            Just replace it ...
            kind regards
            copierfan
            • tamboknon
              • Sep 2015
              • 62
              Hi Sir, anybody can give me a concrete solution. Thank you
              • copier tech
                • 8131
                What exactly did you replace? a complete NEW fuser unit assy? or a used one?
                From your sample a caked up heat sink roller causes this issue. I simply remove them they run better.
                • zoraldinho
                  teacher-guide-expert-guru
                  • Mar 2008
                  • 5007
                  Do you get problem If you make force stop also before fixing?
                  • tamboknon
                    • Sep 2015
                    • 62
                    Sir, I replaced the whole fixing ass'y and also do the force stop before entering the fixing and while in the fixing assy to determine but the problem is not there. The machine has a finisher unit the rollers are good. I'm confuse where the problem occurred. TIA
