IR 2870 wave ype printing
  • kstan268
    • Apr 2012
    • 85
    i had a Ir2870 having this problem wave type print or make copy need your guy help...Never see tihis type of printing before pls help tq
  • Burdy500
    • May 2016
    • 44
    Re: IR 2870 wave ype printing
    First try latest firmware but this looks like wrong loop at registration... clean or replace the registration clutch
    with kind regards
    Copierfan
    • IndoCE
      • Nov 2014
      • 14
      Replace bearing lower (press) roll
      • Burdy500
        • May 2016
        • 44
        with kind regards
        Copierfan
        • roho
          • Mar 2009
          • 844
          you may be looking at a controller issue, not a mechanical one. Looks controller related to my eyes.
          • dan7777
            • Dec 2012
            • 680
            Check copy off glass. If it is the same watch the scanner and see if it hits something. Not the same inspect ADF and see what is wrong.
              • 23008
              If that irregularity is 30 to 40mm from the trailing edge, I would look at the fuser drive and fuser speed. If the fuser speed does not properly match the registration roller speed (in this case fuser too slow), there becomes a buckle in the paper between the transfer roller and the fuser. When that buckle releases, the paper shifts. All you have to do is hold one of these copies up to the machine, with the trail edge of the paper just leaving the registration roller, and note that your shift is exactly where the transfer roller is transferring the image.
              It might be a drive issue like gears or bearings, or there may be a fuser motor speed adjustment in need of tweaking. =^..^=
              • kstan268
                • Apr 2012
                • 85
                with kind regards
                Copierfan
                today change registration cluth ...still yhe same problem any idea
                  Problem :
                  The Copies Look Wavy and Intermittently the Image is Compressed from Lead to Trail.
                  Solution :
                  In this case, the ground leaf spring for the registration roller was deformed. Reform or Replace the Leaf Spring to resolve. ( Part number for the leaf spring is FC5-1564-000 )
                  • dan7777
                    • Dec 2012
                    • 680
                    Maybe do an internal print and see if it is in the optics or machine. Maybe a test of the grid pattern which I don't remember which test print that one is. I have see what your sample looked like from the scanner either bumping something or moving because a cable was wound around the pulley wrong. I am thinking this movement from the optics makes the wave. I just don't see how the registration clutch or fuser can make that line like that. But I have also seen some strange stuff over the years.
                    • roho
                      • Mar 2009
                      • 844
                      I thought it printed as well as copied this defect. I still strongly suspect a main controller, however, it's a gut feeling.
                      • roho
                        • Mar 2009
                        • 844
                        Originally posted by skynet
                        Problem :
                        Solution :
                        [ATTACH=CONFIG]34436[/ATTACH]
                        Missed this reply, this is worth checking into, believe I've had another tech with this now that I am reminded.
                        • dan7777
                          • Dec 2012
                          • 680
                          Found this. Not sure what cross feed is but maybe opposite of feed? Don't know what M3 is. That would mean getting up and finding a manual. The grounding spring mentioned earlier was also a cause.
                          Product :
                          imageRUNNER 2270 / 2870 / 3570 / 4570
                          Title :
                          Wavy line in cross feed direction
                          Problem :
                          On long runs some copies will have wavy lines in cross feed direction. This happens on copies, prints and engine prints. Replaced Fuser, DC Controller, Main Controller, Registration Clutch and Registration Roller with no change.
                          Solution :
                          After replacing M3 { FK2-0367-000 } issue was resolved.
                            • 23008
                            Product :
                            Title :
                            Problem :
                            Solution :
                            Fuser drive motor. Thank you Google. =^..^=
                            • kstan268
                              • Apr 2012
                              • 85
                              Re: IR 2870 wave type printing
                              But this happen when print from pc as well....today i found out this kind of printing also happen on ir3235 also
