IR c3380i wringling paper
  • Raymann
    • Apr 2015
    • 73
    I have a ir c3380i that wrinkels or james up the first page or two then operates fine. It happens after the fuser which has recently been replaced but the wrinkles are the same. more like a typical fan fold but not as bad. Any experence with
    this ?// thanks Ray
  • techandtrader
    • Jun 2016
    • 335
    Re: IR c3380i wringling paper
    Put new feed rollers in. This has worked for me in one case. Check quality of paper. Humid conditions?
    Customer putting already run paper back into the machine.
    I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
    • tech28
      • Jun 2013
      • 434
      Open fuser door, see the thin red roller, lubricate it, seen that cause you problem, also, check actuators switchs(the steel cover on them) they come loose also and cause intermittent jams. Good Luck.
      • acfife
        • May 2012
        • 63
        Try replacing the orange del roller on fuser door
        FC7-2395-000 Orange del roller
        FU5-1559-000 Bushes x 2
        • Raymann
          • Apr 2015
          • 73
          If it is part of the fuser assembly then it is brand new. Should I lube with silicon oil? this is an odd request but I am willing..........
          • tech28
            • Jun 2013
            • 434
            Yes, that's the roller I am talking about, lubricate it, the bushings dry up and the roller doesn't turn freely. After a few copies, it kind of frees up and lets paper go thru ok, but after sitting , will cause problems again.
