Transfer Belt
  • q555
    • May 2015
    • 81
    Transfer Belt
    Do you guys clean the transfer belt of any machine with a specific detergent? chemical?
    thanks
  • IndoCE
    • Nov 2014
    • 14
    Re: Transfer Belt
    I used cheap metal polisher - brasso , maybe canon not recommended but very powerful
    • q555
      • May 2015
      • 81
      Re: Transfer Belt
      Thank you Indoce for this information
      anyone else who uses cleaning detergents for transfer belt?
        • 23008
        Re: Transfer Belt
        On rubbery transfer belts I use Contractors De-Solv-It (orange oil based solvent) followed by a rinse of alcohol.
        On mylar-like transfer belts I use paraffin lamp oil followed by a rinse of alcohol. You cannot scrub on mylar-like belts. Wipe lightly only or you will scratch the surface.
        You'll have to run 100 or more LTR images to squeegee off the remaining solvent from the primary belt. Image quality will gradually come back.
        • q555
          • May 2015
          • 81
          Re: Transfer Belt
          great information you got there blackcat, thank you
