CANON IR ADVANCE C2225
  • Hoosierdaddy
    • Oct 2016
    • 181
    I am looking for a gear that is on the #1 paper cassette. It is a 8 tooth gear and i am having a hard time finding this part and or part number. It is not a round gear, but kind of shaped like a slice of pizza!! It meshes with a round gear that makes contact with the paper lift motor. Any help would be appreciated.
    Thx in advance
    hoosierdaddy
  • Ctl-Alt-Del
    • Jul 2006
    • 430
    Re: CANON IR ADVANCE C2225
    Thx in advance
    hoosierdaddy
    It the book, #20 in the image below is: Gear, 30T p/n:FE2-0623-000, but if you try to order it Canon has an updated part number and description so what you're probably looking for is:
    Gear, 8T p/n: FE4-3901-000
    Good Luck!
    • copier tech
      • 8143
      Yes this is now mode out of metal so it won't break!
      • Ctl-Alt-Del
        • Jul 2006
        • 430
        Mita had the same shitty plastic gear on an analog machine years ago (DC-2556/DC-3055), after 2 or 3 revisions they finally went with a metal gear as well.
        • JPiek
          • Oct 2014
          • 435
          Had the same issue this morning. No paper from tray1. No lift either...
          Customer: "Oh, ehh, we found this plastic thing in tray 2.." and shows me the 8T gear...
          "The tray made some noise when we put it back after adding some paper.."
          Thanks to you guys we now ordered the new FE4-3901 one... Wondering why one is called 30T and the other one 8T though...
          [edit: mixed up the partno's]
          Johan
