Canon Advance 6265 HARD DRIVE REPLACMENT !!!
  • Abeldls789
    • Oct 2016
    • 2
    Greetings,
    I am needing (2) Canon Advance 6265 hard drives - have 2 units that crashed on me. If anyone has even at least one that's fine for now. Need it loaded with operating system installed. PLEASE LET ME KNOW ASAP ANYONE PLEASE!!
  • teckat
    • 16083
    Re: Canon Advance 6265 HARD DRIVE REPLACMENT !!!
    Originally posted by Abeldls789
    Greetings,
    your looking for a HDD with cloned firmware from another printer----------------------asking for trouble
    just go and buy two/ get firmware/
    then format with firmware format file inside printer & then re-load firmware using a registered ver. in SST
    (or place a service call to an authorized dealership ) get done right
    Canon OEM HDD
    FK4-1550-000--------- iRA 6275 / 6265 / 6255
    • Canuck
      Tech Specialist
      • 1713
      If you have USB packaged firmware you don't need service support tool to flash machine. Stick flash drive in port, hold down 2 and 8, then turn it on and follow the screen info
      • teckat
        • 16083
        Good reminder, don't think poster has any firmware ?
        • jiongpao
          • May 2009
          • 413
          Hi, where can i buy the latest firmware of IRA6265 and IRA4225? If i bought the firmware how can i load it to pendrive as USB packaged firmware? As i assume loading using USB is far more convenient than using SST ?
          • bobburnsreb
            • Mar 2015
            • 233
            Hytec stocks most copier replacement drives by OEM part number. Hytec is able to keep your hard drive replacement costs low due to volume-sourcing capabilities on new and refurbished hard drives. Search the catalog by OEM part number to order hard drives.
