canon ir 1024
  • Orion2010
    • Jun 2015
    • 176
    canon ir 1024
    hello to all,
    i have problem with canon ir 1024 i replace drum, but the same problem again IMG-20161106-WA0001.jpgIMG-20161106-WA0000.jpg any idea?
  • copier tech
    • 8132
    Re: canon ir 1024
    That looks like the customer has left the door open & sunlight has damaged the drum, I have seen that a few times over the years. Is the side of the copier facing a window!?
    • Orion2010
      • Jun 2015
      • 176
      Re: canon ir 1024
      this problem is, with old drum and new drum
      • copier tech
        • 8132
        Re: canon ir 1024
        Ok so its not "the same problem again" the new drum did not fix the issue?
        Are you fitting a genuine Canon NPG-32/C-EXV18 unit or rebuilding?
        • Orion2010
          • Jun 2015
          • 176
          Re: canon ir 1024
          the drum is compatible not genuine
          • copier tech
            • 8132
            Re: canon ir 1024
            No further questions your honour............................................ ...
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5007
              Re: canon ir 1024
              Something block laser light.Probably duck tape or similar.
              • teckat
                • 16083
                Re: canon ir 1024
                are u a tech---
                Laser Scanner Unit
                When reflected by the 4-face polygon mirror, the laser beam moves through the imaging lens, and is bent by the reflecting mirror to reach the photosensitive drum.
                At this time, the laser beam also is directed to the BD circuit of the laser driver/BD PCB.
                As the 4-face polygon mirror rotates at a constant speed, the laser beam scans the surface of the photosensitive drum at a constant speed, thereby removing charges
                and forming static images.
                • DocuCare
                  Re: canon ir 1024
                  Hi have you checked the Bias Trasfer Roller on the Front Door. Also check the Dev unit. Good luck...
