canon r ADV 5051 dirty when print and copy
Re: canon r ADV 5051 dirty when print and copy
I had the same isue on a 5030, first full color A3 print on glossy paper was ok, next prints where like the sample...
I copied some PG10's and observed the fixing temp in servicemode, it dropped after the second print each time...
If it is a fixing issue, you can smear the tonerwith your finger right after it comes out of the printer...
I changed papertype to heavyer paper and it fixed he problem. If that doesn't help ypu should check the fuser assy.. Not sure wich part does the actual heating...JohanComment
