iR Adv C5035 Update firmware
  • Peter Sim
    • Sep 2008
    • 445
    Hi all,
    Need help .Anybody have this issue?
    After update to the latest firmware thru USB ,everything was find but DF suddenly cannot function
    Check in the service mode under version ,Df are not in use.
    Please help.
    Thank you in advance.
  • Peter Sim
    • Sep 2008
    • 445
    Re: iR Adv C5035 Update firmware
    I fond this on the teckat thread:
    If i want to update only R-con thru USB with should i choose
    1)upgrade (Auto)
    2)upgrade (w confirmation)
    3) upgrade (overwrite)
    4)Format HDD
    5)Backup
    7)clear download
    8)download menu 2
    9)other menu
    • copier tech
      • 8144
      1)upgrade (Auto)
      4)Format HDD
      5)Backup
      7)clear download
      8)download menu 2
      9)other menu
      If you only want to upgrade the R-CON only put the R-CON firmware on your USB, choose this when creating the USB stick in the SST (uncheck the files you don't want)
      However it is always best to upgrade all the system software files as if you only upgrade one there maybe incompatibility issues with old/new software.
      Personally I always use option 1, Auto update never had an issue with this method.
      • Peter Sim
        • Sep 2008
        • 445
        Thanks,but still the same as i follow the step the bulletin says.I also downgrade the R cond and update back.
        Any one help please....
        • crusu
          • Jan 2025
          • 2
          I have a C5035, throws error E000602-1213, looks like that is HDD problem. So where can I get the firmware to try to reformat the HDD or replace the HDD and flash the firmware to a new HDD?
          • ADV COPIER
            Pemain
            • Nov 2022
            • 256
            Contact me on my number
            Let's Drink our Coffee
            WhatsApp +62895325228383
            • copier tech
              • 8144
              Yes, try formatting the HDD & updating the firmware.
              We can supply this for you, drop us an email.
              www.printerfirmware.co.uk
