IRadvC7260i- Colour Mismatch
  • MunsterTech
    • Sep 2014
    • 381
    [CQ] IRadvC7260i- Colour Mismatch
    hi,
    I am going to a IRadvc7260i tomorrow with blurred copies on colours, another tech has cleaned the patch sensors and made sure the shutter was moving correctly, one thing he was concerned about was that Auto Colour Mismatch failed every time he attempted it. I would like to know exactly what this Mismatch does, what controls it and what causes it to fail...any help gratefully received.
    tks MT
  • guitar9199
    • Sep 2016
    • 1100
    Re: IRadvC7260i- Colour Mismatch
    Had one of these a good while back, and Canon Help Desk walked me through a service mode setting that "re-Homed" the laser units. After that, Color Mismatch and gradation worked just fine.
    I can't remember what those settings were... I've slept since then, but if you call Canon help line they can walk you right to it.
      Print off a PG6 and look fir the colour that's out of position.
      Lv.2 and perform LD-ADJ-? colour thats out
      COPIER > FUNCTION > LASER
      LD-ADJ-Y Restore Y Skew Crrct Motor initial pstn
      Details When Y-color skew volume in vertical scanning direction is larger
      than estimation, the Skew Correction Motor (Y) is locked, and color
      displacement cannot be corrected even when color displacement
      correction control is executed. This item places the Skew Correction
      Motor (Y) to the center position in such cases.
      Use case When replacing the Laser Scanner Unit to identify the failure position
      Adj/set/operate method Select the item, and then press OK key.
      Display/adj/set range During operation: ACTIVE, When operation fnished normally: OK!
      Default value 0
      Required time 10
      • onlyinnewfoundland
        • Apr 2013
        • 235
        Try doing AT-IMG-X in service > copier > function > misc-p
        That is basically a coarse adjustment compared to what you can do in user modes.
        • MunsterTech
          • Sep 2014
          • 381
          hi guys,
          Went to the machine today, some weird issues, at first glance it looks as if only the Magenta registration is off by about 1.5 mm, all the other colours seem fine, however....The colour mismatch didnt work at first, so took out the ITB assy, cleaned the patch sensors, checked the ITB and cleaned contacts etc...mismatch then decided to work but made no difference to registration. Cleaned registration sensors too. Did laser skew adjustment, still no difference. Did a DC back up, cleared the DC and did the DC res, AT-IMG-X failed and auto colour mismatch failed again too. Took out the magenta drum/dev assy, checked and reseated, but still no difference. The Magenta CQ is not great so have ordered a new magenta dev but dont think that will resolve the registration issue. Bit concerned why the AT-IMG-X fails along with the mismatch...poss DC issue? Will wait for the dev to arrive and see how that goes when replaced then will upgrade the firmware.
            • Apr 2013
            • 235
            Originally posted by MunsterTech
            hi guys,
            Can you post a pic?
            is the magenta skewed at all?
            • MunsterTech
              • Sep 2014
              • 381
              i have some samples in the car which i havent had time to scan to my e mail yet, i did a pg6 and 10, on the 6 the magenta grid can be seen but when it goes to the top of the page the registration seems pretty good, so i guess it could be skewed. ill try and get up the samples asap
              • randall
                • Sep 2009
                • 73
                imageRUNNER ADVANCE C7260 / C7270
                Title : Magenta Color Registration is Skewed Causing Lines to be Not Aligning Properly
                Problem :
                The magenta color registration is skewed causing lines to be not aligning properly. When a PG6 internal test print is run, you can see a definite skew with magenta not lining up with the other colors. Running an ITB init had no effect.The Auto correct color mismatch and AT IMG X adjustments both failed.
                Solution :
                In this case, replacing the magenta laser resolved the magenta image skew. Before the magenta laser was replaced, it was swapped with another color to confirm if would fix the registration skew.
                The part number for the magenta laser is FM3-5000-000.
                Some people may say I have a short temper, but I prefer to call it
                "A swift and assertive reaction to bullshit"
                • MunsterTech
                  • Sep 2014
                  • 381
                  hi,
                  sorry for the delay, the IQ mite not be the best, did it on a irc2220, in a warehouse, but if you zoom in you can see the magenta is skewing off, on the pg 6 you can see at the bottom edge the CQ is perfect, laying on top of each other spot on, but at the top of the page you can see the magenta skewed off by about 1.5mm. Laser adj in level 2 doesnt help.
                  tks MT
                    • Apr 2013
                    • 235
                    Any solution to this after?
                    • MunsterTech
                      • Sep 2014
                      • 381
                      Yea sorry guys, didnt put up the fix, totally slipped my mind, faulty laser in the end. Can swap these lasers around, so swapped with another colour and the fault followed, so ordered a new laser and fixed the issue.
                      • Rachid.Akli
                        • Oct 2011
                        • 595
                        Hi,
                        It is always a nice feeling after resolving such an issues !!!
                        I would like to add a comment for this kind of color mismatch.
                        When looking at the PG TYPE 6, we can see that the mismatch is not uniform along the horizontal direction and it concerns only one side: The rear or the front. In this particular situation, it is always due to the laser. And you confirmed it.
                        Thaks for sharing.
                        Rachid.
                        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
