Anon iradv 8095 e000023-001
  • mramlawi
    • Jul 2011
    • 838
    Dears ,
    im facing a problem with my costumer that thr machine is giving e000023-001 ,the toner bottle is working normally when i tried install toner, checked the developer and looks very good working , can any one help me in this problem,the machinegive the code after some copies .
    Distinguished road makes you jewel in rough
  • bobburnsreb
    • Mar 2015
    • 233
    Re: Anon iradv 8095 e000023-001
    Developer drive clutch.
    • dan7777
      • Dec 2012
      • 680
      Originally posted by mramlawi
      Dears ,
      There was a report of replacing the developer drive clutch to fix problem. They said the developer would stall intermittently.
      • mramlawi
        • Jul 2011
        • 838
        Is theres a pic for it ,should i dessabmle the rear cover to check the clutch
        • dan7777
          • Dec 2012
          • 680
          You should probably find a service manual. I have not seen it, just trying to help.
          E023 -0001 -05 Title Developing Motor error
          Remedy 1. Check the connection of the Connector.
          Motor side: J2319, Main Driver PCB (PCB2) side: J109
          2. Check the voltage of the Developing Motor (M2) J2152.
          If voltage is 0V, check the connection of the Relay PCB
          J520.
          3. Check the load of the Developing Motor (M2).
          Manually turn the Developing Motor (M2) located at the
          rear of the host machine to check it.
          4. Replace the Developing Motor (M2).
          5. Replace the Developing Clutch (CL1). (When an error
          occurs while the Developing Clutch is ON.)
          6. Replace the Main Driver PCB (PCB2).
          7. Replace the DC Controller PCB (PCB1).
          Description Lock error of the Developing Motor (M2).
          Looks like the clutch is on the back of developer drive assembly close to the motor. I would pull the developer out first and see if it is bound up or has bad gears. Then I would go to the developer drive assembly in the back and see if the clutch is rusty or bad. It looks like you have to remove several things to get to the dev drive assembly. I don't have a manual I can give you. I have serviced many 8105's but have not seen that code.
          • mramlawi
            • Jul 2011
            • 838
            I checked the hooper its working normally, but i found the buffer full i removed the toner and cleaned the clutch of it ,then i checked the cylander and i removed the toner also and then removed the rear clutch and cleaned it the machine workes arounf 100 copies and then it give the code , and i measured the motor of the devlopment it gaves me 32 v but i didnt understand why on the connecter of it wrote 24v,
            • mramlawi
              • Jul 2011
              • 838
              Thank you all , my problem solved by changing the developer clutch located on the rear of the machine
