iR 5065 feeder not functioning
+ More Options
Posts
  • Blues Guy
    • Aug 2009
    • 216
    Hi guys,
    Need help anyone of you come across withe ir5065 feeder problem. The feeder not functioning at all when you put a paper in the tray. When you go into service mode level 1 normally will you see COPIER , FEEDER, SORTER, FAX & BOARD. But in my case the FEEDER is missing.
    Have change reader board, feeder board, main con & dc con still the same. Any idea guys that can share with me ?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: iR 5065 feeder not functioning
    Did you try reload firmware? Sensors init?
    • Blues Guy
      • Aug 2009
      • 216
      Did you mean copier firmware ? I can't do the sensor int as the FEEDER is missing now
      Any way I will try reload the machine firmware. Thank you
