ir 550 error 218
  • pontiac
    • 420
    ir 550 error 218
    Error code 218. I have replaced exposure lamp, dc controller and lamp inverter pcb. I have tried clearing error code in service and still have problem. Canon has no bulletin or fix listed for this problem. Has anyone run into this error. Help is appreciated. THANKS
    • 23009
    This is the only reference I can find:
    E218. No 38VDC or 24VDC to the intensity PCB. The temperature of the fuser reads 180 degrees. The I/O address does not recognize a lamp in the circuit. Reseat the connectors on the DC controller, and reset the printer PCB.
    I hope it helps. =^..^=
    • OtherTech
      • Aug 2007
      • 94
      When you replaced the lamp did you replace the heater on the lamp? Often the fix for e220 and e222
      • pontiac
        • 420
        ir 550 e 218
        Yes i tried a brand new lamp with new heater still the same problem. i had the copier brought in to the shop so i wouldnt have to keep going back and forth. Any other suggestions are appriciated. thanks
