IR210 dark background
  • repeatcopiers
    • Sep 2008
    • 591
    We have a IR210 in the field that has a dark background on copies. We have changed the Power Supply, DC controller, Exp lamp and drum......no change at all. Any suggestions??
    • 23010
    Have you done an Auto Shading Adjust? =^..^=
    • kwazimoto
      • Jan 2007
      • 199
      the back ground is it heavy or light ??? or is it only on one side of the page??? please give some more info..
      • roygunawan
        • 12
        clean up the developing assembly and replace the toner with the right toner.
        • Peter Sim
          • Sep 2008
          • 445
          What about the ip board?When you change power supply and lamp,Did you do the adjustment....Service mode>Function>R&D /factory shading auto correction and adjust lamp setting?Power Board label setting?
          • smiley
            • Aug 2008
            • 615
            try to cleane the ccd
            there is no glory without sacrifice
