canon IR 2830
  • 1stcavvet
    • Apr 2015
    • 231
    [Misc] canon IR 2830
    I know this sounds like a trick question, How do you get the pick up roller off the spindle Tray 1 and 2 The feed and sep are a clip on the roller, push it and pull the tire off the spindle. Not so with the pick up, a little skinny roller with a ribbed rubber area, smooth bore going straight thru. I see a sort of clip push it pull it ??? WHAT please let me know THANKS and MERRY CHRISTMAS
  • copier tech
    • 8164
    Re: canon IR 2830
    If there is a tiny metal clip first pull this off, then you can remove the pick up roller in the same way as the feed/sep.
    The metal clip was a Canon mod to stop the pick up roller falling off!
