Problem during giving printouts
  • Sahil102
    • Sep 2016
    • 26
    [Misc] Problem during giving printouts
    Whenever I give a printout command from my computer to Canon ir 3245 ,it goes to the machine but no print comes out. I can check the command in the machine logs with the status as `NG`. Can somebody help.
  • copier tech
    • 8103
    Re: Problem during giving printouts
    Do you have user ID's set up?
    Are you printing from a Windows environment?
    • 20 year tech
      • May 2014
      • 577
      what driver are you using ? that model did not come stock with PS or PCL, believe they had ufrII out of the box.
      • teckat
        • 16083
        who set up your printer environment
        • Sahil102
          • Sep 2016
          • 26
          No user ID setup. Giving from Windows XP 32 bit operating system.
          I am using pcl drivers.
          Some file types printout comes out but some does not.
          I think issue with my file type. I was giving Photoshop.pdf file for printout.
