How to use REMOTE OPERATION VIEWER on Canon IR 3570 or IR 3300
  • princepriyu
    • Aug 2025
    [Misc] How to use REMOTE OPERATION VIEWER on Canon IR 3570 or IR 3300
    Hello
    does the remote operation viewer works with old photocopiers like CANON IR 3570 or CANON IR 3300
    i am having these types of machines. i am eager to know if the software is compatable with both the machines
    IF YES Please guide me how to enable the option and use it
  • teckat
    • 16083
    Re: How to use REMOTE OPERATION VIEWER on Canon IR 3570 or IR 3300
    Originally posted by princepriyu
    Hello
    RUI setting under Additional Functions > System Settings > REMOTE UI ---set "ON"
    On your PC, open up a browser and enter the ip address of your copier so the RUI can open.
    Firmware is different between these to series-
    iR 2270/4570/3570/2870
    iR 3300/2800/2200
    • princepriyu
      thanks for reply
      i am using RUI for both the machines
      but i want to use them via REMOTE OPERATION VIEWER
      but every time i try to connect via the software it says
      "could not connect to the device of the specified address.
      do you want to try to connect again?"
      but when i try with a browser RUI
      it works
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        On this two model you can not use remote viewer i believe.
        If I remember password input is necessary when it is set.
        The setting method of the password
        Settings/Registration > Management Settings > License/Other > Remote Operation Settings > On
        Default is "None".
        ps: IR and IRA are different viewers.
        • zoraldinho
          • Mar 2008
          • 5015
          iR 3300/2800/2200
          I believe he asking about remote kit and not rui.
          • charm5496
            • 2387
            the remote operator kit requires the purchase of a license key that needs to be installed on each copier
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              I highly doubt the kit would be available for machines that old, even with the latest and greatest firmware.
              They are just too different.
              • teckat
                • 16083
                imageRUNNER 2270 / 2870 / 3570 /4570
                With system software version 32.01 and higher
                Remote Operator’s Software Kit-A1 is supported.
                This option requires LMS activation.
                Remote Operator Viewer (ROV) v2.1.0.
                The ROV allows a network user to operate all the imageRUNNER or imageRUNNER ADVANCE control panel functionalities such as Copy, Mail Box , Send and Fax directly from his or her PC.
                DETAILS:
                Changes:
                • Added support Microsoft Windows 8, 8.1 and 10
                • Added support Microsoft Windows Server 2012
                Supported OS:
                • Microsoft Windows Vista (32-bit & 64-bit)
                • Microsoft Windows 7 (32-bit & 64-bit)
                • Microsoft Windows 8 (32-bit & 64-bit)
                • Microsoft Windows 8.1 (32-bit & 64-bit)
                • Microsoft Windows 10 (32-bit & 64-bit)
                • Microsoft Windows Server 2008 (32-bit & 64-bit)
                • Microsoft Windows Server 2012 (64-bit)
                Supported Devices:
                imageRUNNER or imageRUNNER ADVANCE models with Remote Operator’s Kit enabled.(ROK)
                NOTES:
                Microsoft .NET Framework v2 or later is required for this application
                ASSOCIATED FILES:
                File Name / Description
                Remote Operator Software V21.exe
                Remote Operation Viewer v2.1.0 Software
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  So, I'm surprised the iR3570 supports it.
                  I see the iR3300 does not.
                  I doubt anyone would be interested in paying for the kit, though, at least not at this point.
