Replacing Hard Disk of IR3300
  • princepriyu
    [Misc] Replacing Hard Disk of IR3300
    Hi All
    I am having CANON IR 3300
    with HDD capacity of 5.6 GB
    what is the maximum extendable capacity of HARD DISK
    can i install 40GB ??
    if yes please HOW to do it ??
    same question for CANON IR3570
    thanks
  • guitar9199
    • Sep 2016
    • 1100
    Re: Replacing Hard Disk of IR3300
    Canons are notorious for only accepting SPECIFIC hard drives. Hytec sells HDD's that work.
    IR 3300 - Part# FK2-4907-000
    IR 3570 - part # WM2-5199-000
    Good luck....
      • 16083
      Originally posted by princepriyu
      Hi All
      thanks
      iR3300
      Standard 128MB RAM +
      5.1GBHDD
      The imageRUNNER 2200 / 2800 / 3300 / 3300i:
      They have an internal 5.1 GB or 10 GB hard drive that is shared for copy/print/fax functions.
      The hard drive can hold approximately 3,700 originals for copying, printing, and faxing functionality.
      iR3570
      STD/MAX COPIER MEMORY : 512MB RAM,+ 20GB HDD
      The imageRUNNER 2270 / 2870 / 3570 / 4570 / 5570 / 6570 / 8070/ 9070 / 85+ / 105+ / 3045 / 3035/ 3030 / 3025 :
      They have an internal 20 GB hard drive.
      Max Paper capicity 4,750 sheets
        • 16083
        View Models Supported
        FK2-4907-000
        Manufacturer Model No
        CANON IR2200
        CANON IR2220N
        CANON IR2220i
        CANON IR2800
        CANON IR3300
        CANON IR3300i
        CANON IR2270
        CANON IR2870
        CANON IR3570
        CANON IR4570
        CANON IR3320
        CANON IR8070
        CANON IR5570
        CANON IR6570
        CANON IR2230
        CANON IR2830
        CANON IR3530
        CANON IR9070
        CANON IR105+
        CANON IR85+
        CANON IR5070
        CANON IR3030
        CANON IR3035
        CANON IR3045
        CANON IR3025
        CANON IR3320N
        CANON IR2200i
        View Identical Sales Part Numbers
        FK2-4907-000
        Sales Part No
        WM2-5216
        WM2-5160
        WM2-5199
        WM2-5230-000
        B0955760
        B0955763
        950231P
        950258P
        WM2-5216-000
        HDD-6
        9J06M70000
        FK2-4907-000
        9J06M70500
        WM2-5185-000
        WM2-5244-000
        B0955761
        B0955764
        B0955762
        FK2-7429-000
        FY3-0314-000
        FE1-5122-010
        WM2-5199-000
        WM2-5160-000
        H5157119
        4037609501
        G3955300
        A8537000
        B0295760
        WM2-5158-000
        FK2-4907-00R
        FK2-7429-00R
        WM2-5216-00R
        WM2-5230-00R
        WM2-5244-00R
        WM2-5158-00R
        WM2-5160-00R
        WM2-5199-00R
        Sales Part No: FK2-4907-000 Warranty Type: 365 Days
        Customer Part No: Foot Note: Destruct or Sanitize - Call Today!
        Description: HARD DRIVE 2.5 IDE Department:
        • vigour
          • Aug 2010
          • 1038
          I used up to 20 gig drives on iR3300 many moons ago when they were in production.
          Then we would modify the system software
          Bigger drives would end up with missing functions
          • Canuck
            Tech Specialist
            • 1713
            You can use non Canon HDD in IR3300 but you have to modify the HDFormat ift file...tell customer its time to upgrade. I used the small Seagate hard drives in 3300s
            • princepriyu
              can i install 40GB Hard Disk Drive to Canon IR 3300 or to Canon IR3570
                • 16083
                3300==10 GB
                3570 ==
                20 GB
                that is all u need
                • Canuck
                  Tech Specialist
                  • 1713
                  40 G will work...
                    • 16083
                    Originally posted by Canuck
                    40 G will work...
                    Works if they need to store The Encyclopedia Britannica.
                    • Canuck
                      Tech Specialist
                      • 1713
                      I use 80 G Seagates....dirt cheap
