Ir3245 strange problem
  • copicatt
    • Nov 2008
    • 366
    Customer has a double image issue intermittently. 3 or 4 times a day. Has noticed it on faxes and prints from pc. Attached example. It's not ghosting. Has two perfect images on the page. I can't duplicate the problem. Has not noticed on copies.
    Running LTR-R direction from all trays. Ideas?
    Attached sample
  • guitar9199
    • Sep 2016
    • 1100
    Re: Ir3245 strange problem
    First thing I would do is flash the firmware, using "Overwrite All"....and see if that makes it go away.
    • copicatt
      • Nov 2008
      • 366
      And if you notice the fax header is not doubled
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        Memory?
        • Canuck
          Tech Specialist
          • 1713
          Try cleaning the silver reg roller ground clip at the front of the roll. Put some black conductive grease on it. I have seen them cause electrical noise that makes the Dcon tell the laser to do weird things.
